help speedo meter
hello pls help recently i encounter a problem with my speedo meter, the need is not steady and is jumpy from 0 -40 but when i reach the speed of 50kmh and above the reading are steady can any help do i have to change the speedo meter cable what are the possible compabible one thanks :o
Grease the cable. Disconnect your battery (+) before you pull the gauge cluster out to disconnect the speedometer cable.
