help removing front rotors
hi,i'm trying to replace my front rotors and up to the point where i removed the six 12mm nuts from the hub flange.my problem is i cannot get the hub flange off either side no matter how hard i hit it with a drift and a very large hammer.have i missed something,is there a special way to get these things off,can't use a puller as there's nowhere to grab.giving up for tonight,very frustrated.try again tomorrow.any insight would be greatly appreciated.
i removed six washers with the nuts,are there other washers also?it looks like there is something at the base of the studs,maybe 1/16"thick.how do you get them off?
hit the stud with a brass drift should pop the cone washer off, x2 on removing the lock washer and 54mm nut. repack your bearings while your in there.
Be careful about damaging the threads. I put the nuts back on, even w/ the end of the studs and hit that w/ a brass drift/mallet to get the cone washers off.
IIRC there may be 2 threaded holes between the studs that hold the cone washers, in the event you cannot jar the cones free you can thread a bolt in either hole, tighten them down evenly, which forces the flange up. Just lift it a couple mm. Remove the 2 bolts and tap the flange back down, all the cones should be free.
I cant remember if my 80 has these threaded holes, I know my Hilux does... makes it easy. If not, like the previous post says, thread the nuts back onto the studs a bit, and tap with a hammer
The first steps from Birfield Repack should show what's involved in getting the rotor off.
cheers,
george.
I just did a knuckle rebuild yesterday. Use a *brass* drift and hit each of the studs with the cone washers from a slight angle (instead of 90 degrees straight on, do 80 degrees) and from three different angles as if looking at the stud like a clock - try 12, 4 and 8. You'll notice the ends of the studs are a slightly smaller diameter than the bolt shank so if you dent them a little bit the nut will still go back on. It doesn't hurt to use some penetrating oil on the studs the night before.
If you do all the above, they will probably break free with 3-6 strikes each. The factory diagrams showed a 90 degree/straight on strike, which didn't seem to work for me at all.
Despite this theory, I still erred on the cautious side and also left a nut threaded down the stud to clean up any threads in case I knicked them up somehow.
Yes, that's why I posted a link to my site. The exact picture is:
cheers,
george.
cheers,
george.
The problem I see here is that you are also hammering the roller bearings inside too. Sure, they are very strong but this shock loading can probably be prevented by using the other techniques. The factory service manual recommends the brass drift on the stud, and they are hammering in such a way as to spread the shock load over all the tapered bearings.
Yes yes, I'm being super picky about this... but just wanted to give another perspective ;)
