Help needed with attaching 2F Manifold (CA Spec)
Norman, OK
2 questions:
1) My '77 CA Spec manifold appears all original, the "horns" are bolted onto the manifold as shown in the microfiche diagram, yet the horns have no holes drilled for the end bolts. The head has two 10mmx1.25 holes and the gasket has holes. The microfiche diagram shows bolts going directly into the gasket but that can't be right. So does the CA manifold omit the end bolts?
2) The microfiche diagram indicates two12mm exhaust studs.. Where are the studs placed? I'm guessing where I positioned them ?
Thank you!
