Could use some help on this one. 1994 ODB1
Problem – Stable Code 25. The initial code was Code 21 (Bank 1 O2 sensor) however after a few ECM resets and a few weeks of travel, the code changed to Code 25 (Lean) and sometime Code 26 (rich). I have never had the Code 21 since, however since that was the original code I decided to start my testing with the FSM troubleshooting tree for the O2 sensors. When I followed these steps I was measuring 0 volts at VF2 and ultimately ended up with at the “Replace the heated Oxygen Sensor”. I should point out that my O2’s are OEM with less than 15K on them. In any case @beno supplied a new set under warranty. I fitted those, reset the ECM and the code (25) came back within about 5 miles and 2 or 3 starts.
I have a Toycom data reader and I can see that Bank 2 O2 is not switching from rich to lean which lines up with me measuring 0 volts at VF2 in the DLC diagnostics box.
Today I printed the wiring diagram and set about checking for continuity across the O2 circuits. This is what I tested so far:
From the O2 engine side connectors:-
1) +B (Yellow/Red) on O2 Left and +B (Yellow/Red) on O2 Right = 0 Ohms
2) +B (Yellow/Red) on O2 Left to Chassis = 400 Ohms
+B (Yellow/Red) on O2 Right to Chassis = 400 ohms
3) OX2 (White) to OX2 in DLC = 0 ohms
OX1 (Blue/White) to OX1 in DLC = 0 ohms
4) Turned on Ignition +B on Left & Right Sensor = 11.5V
5) HT1 (O2 Harness) to HT1 (ECM) = 0 ohms
HT2 (O2 Harness) to HT2 (ECM) = 0 ohms
6) OX2+ (O2 Harness) to OX2+ (ECM) =0 ohms
OX1+ (O2 Harness) to OX1+ (ECM) =0 ohms
I think my problem is the 0volts at VF2 but maybe I am chasing a dead end with that. Vacuum hoses are all new and the VAF / Throttlebody intake pipe does not appear to have any cracks. I had a go with the starter fluid leak detection method but saw no issues.
Any help is greatly appreciated...
