Help Needed-TG Spindle Lock Nut
Tacoma, WA
I'm in the middle of installing the TG locking spindle nut on the ps side and I have a question. Do I reinstall the out locking nut also? There aren't enough threads left and it wouldn't sit flush anyway due to the little locking bolts.
I'm assuming installing this replaces the inner lock washer, preload nut, lock washer, outer washer, and the outer locking nut? Not sure if terminology is all correct. Thanks in advance.
To clarify, install TG nut, adjust the bearing preload, install locking portion of TG, and then just the lock retaining ring on the end of the spindle?
I think you are correct. It replaces all but the thrust washer.
Outer bearing, thrust washer, TG spindle locking nut, spindle locking washer, washer, cap screw.
Yeah I have the pdf but after the locking ring is installed it just says reassemble hub in the reverse order. The next step in reverse order would be the outer washer and nut. Thanks for the link though.
You don't reuse outer nut, just thrust trail gear nut then lock washer ,don't forget the c clip on end of the axle
When you say lock washer you are referring to the ring that the little bolts lock down from TG? Thanks for the feedback.
Also, is this normal? This is with the TG nut locked in place.
Yes that is normal. The snap ring keeps the movement to a minimum. The PDF defines the hub as the locking hub, ie the selectable hub found on part time toyotas.
