okay, so here is the detailed writeup. The brake controller is wired properly, but the brake switch seems to be the problem. There are 4 wires with the prodigy black, white, red, blue
black is 12v and thats hooked up right
white is ground, pretty sure its a good ground
blue goes to the controller, that's hooked up right (brakes on the trailer work)
red is supposed to go to the cold side of the brake switch. it was hooked up to the green with white stripe on the brake wire headed back on the vehicle. it was originally on the brake switch (green with white stripe) but was moved here hoping it would help.
Following the wires back I get this under the bottle jack.
green (turn right) is spliced into green/yellow
yellow (turn left) is spliced into green/black
red (brake) is spliced into green/white
white (ground) is spliced into white
brown (tail) is spliced into brown
These 5 wires go into a cheap ass looking converter that the guy told me is water tight (its not)
From what I can tell the converter combines the brake and tail function since 5 wires need to go to 4
This is whats in the box
I don't think this converter is the issue, since all cruiser have 5 wires that need to be resolved to 4 and this looks pretty simple.
Again, the lights work, the brakes work and everything is running great...except my cruise doesn't work. its strange though, its like its on the cusp of working and sometimes
does work for a little, then it kicks out and flashes again. Bad ground or an issue with this converter box is all I can think of. I don't have what I need, but I was thinking about grounding the controller to the Neg battery terminal or the chassis ground that's there being used for the ECU. I assume anyone with an 80 has a similar lighting setup if you have a 4 flat (5 into a converter and 4 out) so I can only speculate as to why this isn't working. Another theory would be that the green with white stripe is not the cold wire, but I would guess it is since the other wires are red.
Also, whats this? anyone know? I was thinking it was a factory plug for brake wiring, but I tested and couldn't get voltage on any terminals
Its on the same loom, but not the same wires as are spliced into.
