Help needed 12ht
Australia
hey all I have inherited a 75 series with a 12ht in it from a 60 series runs good however won’t shut off. Iv done a tone of research and replaced the vac lines to the vsv still won’t shut off looking at the the vacuum pump my fitting only has one port that’s solid and not the one to hook the vacuum hose to pic 1 is like mine when I assume I need pic 2
Or a tee hose fitting from the single port and take two hoses feom the tee out to needs including vsv?
Hi mate, your assumption is correct, you need the fitting with the extra nipple. That is the vacuum tap for all the engine accessories including the shutdown VSV.
It would seem that they where taking vacuum from the intake iv ordered a vsv in case it’s cooked, would you happen to know what that part is called I can’t find it anywhere online, also when i remove that fitting it does have oil in it is that normal.
