Help! need suspension advice.....
Hi all, bought a LC 80 last year and have been trying to bring it back to onroad and offroad ready to enjoy with my kids etc. It desperately needs a new suspension and where I currently live the only option is used / refurbished shocks / Toyota genuine shocks (really expensive and need to be ordered) and Ironman 2' lift kit (foam cell shocks, front performance springs, rear load springs and steering damper). Personally I love the Ironman option but I am concerned that the load springs would make the height too firm or bumpy and if I just do the shocks than I wont get the lift and I am worried that the existing almost dead shocks could damage or push the new shocks too hard - as it seems that the existing springs have no life left in them.
thanks your your guidance on this guys!
Where in the world are you that you can only get Iron Man equipment?
For a stock suspension, order Old Man Emu stock height springs, and get the replacement Toyota (Tokico) shocks. Not nearly as expensive as some of the others mentioned.
There may be locals to you that have what you need.
When you take your current shocks off SAVE ALL YOUR MOUNTING HARDWARE!!! The 2 inch retainers/washers range from $8 - $25 each (and up) depending on the dealer and the Tokicos don't come with that hardware. In fact I learned that whether or not other aftermarket shocks come with that hardware is hit and miss. fwiw
He's didn't indicate where, but he's somewhere outside the US. Depending on import duties and the pricing strategies of Toyota dealers there, it's possible the stock Tokicos are expensive. Perhaps he was quoted a dealer-installed price? In that case, see what the parts only price would be and either DIY or find a cheaper mechanic.
You might also look into what buying and importing yourself might cost. You might save enough anyway to make it worth the freight and duty/taxes that would be charged.
Don't go with a refurb shock IMO. Sounds like something you'd expect to fail again.
As for your coil springs, they get tired with age. They can sag a little, but it's really more about the performance drop off. Best bet as was mentioned is the OME 861/862 combination. Installing just new shocks won't help much and the new coils will give greatly improved performance. If you have the shocks, all you need are the 4 coils and nothing else, no kit or other parts -- provided you still have on the truck the factory shocks and save that hardware, as mechanist helpfully reminds.
With the Ironman 2" lift, it will probably be enough to require caster correction so she still steers sweet. That and the extra parts will cost you more, and it doesn't sound like you really want or need the lift anyway, just a freshened suspension and ride.
thank you gents for your response - its really helpful. Getting anything from local Toyota is extremely expensive but I have checked and UPS can deliver so I am thinking of just getting either the ARB setup or the toyota parts y'all recommended.
Will post when I get this sorted....
