...I think the pump can be below the cooler - it's the reservoir that needs to be above the cooler from what I understand...
From what I understand, the problem is this:
If everything remains ideal, then yes, once the system is bled, it will work fine. It will be more difficult to bleed, in this configuration, but I'm sure you can do it.
However, if you suck air into the cooler, and it's a local high point in the flow pattern, then it will stay there at the high point and not float back into the res.
, so they say I need the reservoir and closed can which arrives tomorrow...will make bracket and mount. Update everything arrived .............
the aluminum one is a floor squeegee brace and the black metal one is a wheelborrow leg brace...
know what I mean..........I finally got around to taking a pic...this is how I ended up mounting my reservoir to get it high enough to prevent cavitation on the steep climbs. I was fine for 7 or 8 trips but one trip I found enough steep climbe to cavitate and overheat the pump regularly. Hope it helps............
Well...I suppose all I can ask is that you avert your eyes as I drive by with no power steering concerns. I don't really have time to make a functional, utilitarian vehicle pretty....it takes all my time keeping it functional![]()
Get a 60series cannister and mout it on the firewall, in your case with lefthand drive should fit beside your brake booster.
