Help me wire my Kaymar....
Wandering the Wild West
I've been searching all day and trying to figure out how to wire the lights on my Kaymar to the wiring on my Cruiser.
I found that some have done totally custom wiring jobs etc, and that's fine, but it is impossible to just plug them in to the factory wiring like the instructions say?
Also, I bought my Kaymar used and i had to get it sand-blasted and powder-coated and so I pulled the lights out and completely disassembled them and now I cannot remember how to connect back up the ends to the lights--as in which color light goes where... Anybody know or can take their cover off real quick and check it out?
-Ferg-
I think the connector you're looking for is under the truck. There is a wiring harness that runs from side to side near the spare tire carrier, and about midway across there is a connector and a screw for a ground. There was on my 96 at least.
theferg,
Here you go! The ring connector is for ground that attach to the hole in the body, see the 2nd picture.
Sweet! Thanks guys! 4x4CPOSEADOG those pics are perfect! It's dark out now, but I'm sure I'll be able to find them in the morning.
Does my harness look "normal"? I'm concerned about the wires shown in the 4th pic down. Just bare wires showing coming out of the middle of the harness (they can be seen in the first pic as well). Should these go somewhere? Or should they just be capped?
I'll figure out the wiring back to the actual lights. Doesn't look too difficult actually.
-Ferg-
Here two more pictures to connect the wires to the bulbs. First is DS and second is PS side marker.
Now, have some fun connecting them wires:D
[ Posted by theferg. Does my harness look "normal"? I'm concerned about the wires shown in the 4th pic down. Just bare wires showing coming out of the middle of the harness (they can be seen in the first pic as well). Should these go somewhere? Or should they just be capped?]
Your harness is normal. That's the way mine is. The wire on the first pic were capped off and taped up on my harness. I think they are for the trailer wiring, but haven't got the chance to play with it.
I'm sure you already figured this out, but IIRC the one thing that is not directly obvious about the wiring is that you have to disconnect 2 connectors on the OEM harness first and then put in the Kaymar stuff to "reclose" the circuit. IOW, there isn't an empty connector up there just waiting for the kaymar. But a minor inspection will reveal all that since the connectors can only be put in one way.
If you don't have a voltmeter, you can then hook up the terminals at the end to any of your bulbs and see right away what does what.
Personally, I would change the big bulbs to lower wattage ones so they don't burn the plastic too quickly.
Do they really?
Do the Kaymar rear tail light covers melt or blacken with the existing bulbs from Kaymar? Also, is there a cheaper place to get replacement plastic covers than man a fre? I broke one. I've also never hooked up the lights.
Thanks
1156 and 1157 for the bigger bulbs...not sure on the little one
edit: I pulled the bulbs and the big bulbs are both single element...and i found this info in another post.
Trifa 12V P21W 2FZ C3 ---> Sylvania 7506 (P21W) (bigger bulb, 2 in ea. light)
Trifa 12V R10W 2FY E3 ---> Sylvania 5008 (R10W) (smaller bulb, 1 in each light)
Curious.. when did the style of the Kaymar change? As my bumper doesn't quite look like that on the corners, but has the same wiring.
