Help me please!
Charlotte NC
I am trying to swap out the slave cylinder in my 68 fj40. This is the last thing I need to do before I go get it inspected by the state of NC. I got one of the bolts out with no problems. I removed the nut and expected it to slide off relatively easy, but it didnt budge. I have never delt with the older 3 speed types. The cylinder is directly attached to the 3sp linkage, so when I go to pull on it I pull the whole linkage out of line. I really dont feel like damaging the whole transmision, so I need some help. Are the older slaves threaded somehow? Im sure somebody has had this problem before.
Here it is....you can see the bolt sticking out on the left....
The new slave....no threads...
I have been trying to remove this :censor:ing slave cylinder for 4 hours. It might as well be welded to the stud. I pulled and pulled, twisted and beat it with a hammer...I tried everything to remove it. I used penetrating oil, then I applied heat to it. I attached a ubolt to it and pulled it with a chain. I heated it up so much it started to glow...all the while pulling on it. I even attached the end of the chain to a dirtbike and pushed it as hard as I could, but sill nothing. This has to be the original 38 year old slave cylinder ....because they are PERMANENTLY fused together.
I love working on my cruiser...but this is just one of those days....:frown:
Does anybody know where I can get a new slave mounting bracket and linkage bolt for a 1968 fj40...because mine is all ***ed up ?
Mounting bracket? The slave cylinder doesn't have a formal mountingbracket. One bolt [the one you got out] goes into the motor mount bracket. The other has the dual head stud that is stuck in the cylinder. The inboard side of the stud services the tranny linkage, the outboard side the slave cylinder.
There is a small locator bracket that goes from the stud to one of the three motor mount bracket bolts. If that is the bracket you are referring to, you shouldn't need to replace that. If you end up cutting the stud to get it off the cylinder, you should still be able to recover the locator bracket and re-use it.
Pretty sure I've got some of those studs at the shop if you don't find one thru the board.
Good luck.
Mark A.
Yes, I am talking about the locator bracket. Compare the 2 pics...notice the location of the slave cylinder....the bracket is all bent to hell. If I can get the bracket off the motor mount I might be able to bend it back. Luckily I was able to get the tranny linkage disconnected, so no damage was done there.
Im off to bed:frown:
Just try to tap the slave. maybe get it lose
good morning.
Your first picture shows the bracket still bolted to the motor mount by the lowest bolt (marked '5"). Did you get that bolt out?
If you did remove that bottom bolt and disconnect the linkage then the slave should be hanging loose and all you have to do is work it out with the bracket attached by the rusted bolt. Fix it all up on the bench.
