Help me identify this sound/issue!
sxp
Portland, ME
I have a sound that comes and goes, but I can't replicate it whenever I want to. It sounds like a metal whale call or a goose honk mixed with the friction sound from rubbing your hand on an inflated balloon. I thought it was coming from the front end, but I am not entirely sure.
It will happen at least once during most trips, but not always. I need to be at a stand still, and then accelerate for it to be audible. The sound is short, and goes away once moving. It seems to happen more when the truck body moves up more from engine torque. It happens less on warmer days (or I can't hear it).
Any thoughts? I'm trying to get some direction here before I start tearing into things. Thanks.
Is it inside the cab or outside?
Could be front axle spindle bushings. Could also be u joints.
Could he the cooling fan behind the radio.
Could be the idler pulley for alternator or AC.
make sure front shocks are not loose, or the fan shroud sway bar bushings could be dried out
I actually tightened the front shocks up a couple of weeks ago that was my first thought. I do need to check the rest of the bushings though .
Have you checked to see if your front wheel bearings are loose?
The wheel bearings were adjusted about a month ago at a Lexus shop, and one was replaced. I'm assuming it was done right.
Has the sound started after this work was done?
Wish I knew. My exhaust was blown out so I couldn't really hear anything at all. Had the bearings done, fluids changed out, and a general look over preformed after a long trip from Maine to NC and back. I then had the exhaust fixed a week later.
'96 LX450 with 2.5" OME lift and Man-A-Fre 2" drop brackets originally owned by BltByKrmn. The shop looked at the U-joints and pinion bearings since the did a front and rear dif service, and gave them the ok. It sounds like a drying bushing somewhere or a metal rubbing sound. I need to spray up all the rubber bushings to see if that temporarily fixes the issue, but today, it is pouring outside so it'll have to wait.
I'm guessing dry spindle bushings and loose wheel bearings.
Hopefully this closes this thread as I believe I have solved the issue. I pumped some new moly into my knuckles, and so far the front end has been quite.
