Help me find an AC outlet
South Jordan, UT
I just can't believe there's not an AC outlet with a small, simple lid that will close over the top. Not a big outdoor home-type outlet, just a single female plug with a lid/door that closes over the top of it. Like the 12V outlets you can get from marine shops.
Want to install a couple in my 80 with an inverter.
I've scoured the web and couldn't find anything.
I checked out a plug for a Tacoma, but it's way too big.
Anyone?
Hayes
Anyone?
Hayes
2000-2004 Toyota Avalon's have them. My plug cover is about the size of the plug (but no ground)
http://www.interpower.com/ic/images/88010360spec.jpg
Anyone?
Hayes
are you looking for a 2 or 3 pin ?
There is an on/off control switch on the dash under the ignition. Not sure how big the unit is behind the dash. I could dig up the EWD is you're really interested.
Hmmm. Those look nice. I wonder if C-Dan has the part numbers in stock?
-B-
-B-
Be prepared for sticker shock, if it's anything like the other Avalon parts I've looked into. Go for salvage. TAP had a few hulks laying around last time I browsed their website...
Sweet.
That's more or less what I'm looking for.
Thanks.
I'd like a 3-prong outlet--so I won't have to deal with adapters if I want to use something with a 3-prong plug.
The grounded Tacoma outlet was pretty nice, but the thing must have been at leas 6 inches square (and about $30).
I plan on switching the inverter with some kind of relay and switch. The Toyota switches look nice, but I bet their $$ and they're likely set-up for plug and play with a plug I don't have...
The A/C plug for a 2002 Avalon (part# 85530-41030) is $32.38 msrp and yes, the Tacomas (part# 85530-04010) is $32.35....
Actually I think thats quite reasonable, well at least compared to the Toyota inverter ( part# 86210-04010 ) @ $954.53 :eek:
That must be one DAMN good inverter :rolleyes:
Do the Avalon's all have an inverter and does anyone know the rating?
-B-
You shouldn't need to switch the power supply to the inverter in order to control it...
Just tap into the switch that's built into the inverter itself.
Save a few bucks and keep things a little more simple...
Good point, but then I have to open up the inverter...
