Help! Issues before I go to school...
Im moving to go to school and have a few issues to address before I move. Which means I have until saturday to fix them.
Ive been trying to solve my carb/vac issue for a very long time.
I have a Weber 34/34 (K764 K746 34/34 Weber Carburetor Kit Toyota Pickup Truck 22R - JTOutfitters). My problem is in the upper RPMs. I can hold 4g in 1st and 2nd. I do not like to take it above that. As soon as i hit 3rd it stumbles and hesitates above 3200, 4th and 5th are even worse above 3000. Ive messed with it since Ive had it, many long phone calls with wristy later, Im still lost. As is he.
Maybe the secondarys open up to soon?
Issues ive noticed include difficulty starting, and off the wall idle speeds. One day itll be 850 (where its set) the next itll be 1100, Its even gone to 1500 before.
I cannot get it to pull vac over 11. I can go lower, but not higher.
Any ideas? New Fuel pump, ive put regulators on it, etc. But nothing helps.
Ive got a slight ticking noise, like a reoccuring exhaust leak that leaves after i hit 160* on the temp gauge, like a valve... Maybe I just need to re-adjust them.
This is a brand new motor, 3000 miles on it. I mean NEW EVERYTHING. Only thing thats not OEM is the Exhaust Mani and the Weber. Should you adjsut the valves after a certian running period? Besides every 30000 miles?
The Ujoint in the cardon joint (?) is bad, can that replaced? On the pinion. it wobbles, should i worry? its 1/16 movement at the most.
Has anyone ran Rotella 15-40 in there engine? I think 20-50 is to thick and 10-40 is alittle to thin, 15-40 is inbetween... Makes sense to me.
Thanks!
Thanks!
