Help in Wyoming
So now dealing with a new issue. We put the "new" engine in but I don't think I had the torque converter seated properly as the motor would not spin. I tried turning it by hand before actually trying to start it. Now I am afraid that I damaged the transmission pump. Anyone have a know working pump for sale? Is there a good place to buy one that is not going to cost me a ton of money? How hard are they to replace?
So still trying to get some quick answers about the pump. Anyone know of a good place to source them, and are they difficult to replace? Any guidance is appreciated.
Find out if that is actually what is wrong first. Did you bolt the torque converter onto the flex plate with the motor out and then try to assemble? The right way to do it is to bolt it to the flexplate from underneath once everything is mated. Meaning leave the torque converter on the trans. To replace the pump, you have to pull the transmission. I've never removed a pump from that trans before, but most of them can be removed with a pump puller. I have also hillbilly engineered my own puller before.
http://www.toyotapartsoverstock.com...sembly=509843&ukey_make=1060&ukey_model=15437
I am pretty confident the issue is that I don't/didn't have the torque converter seated all the way into the transmission. I plan to pull the trans out tonight, but I am just worried that I broke the pump. I don't want to pull the trans, reseat the converter, re-install, and then burn up the transmission because I broke the pump. I would rather pull the trans tonight, replace the pump, and then correctly assemble everything. I just don't know if I want to take the gamble of putting it all back together only to find out the pump is destroyed.
You'll know if you screwed something up. The splines will be gnarfed or you will see a crack in the pump housing. It may not have hurt the pump at all and you may only have to replace the torque converter.
What makes you think you wrecked the pump? Did you jam it in there and start cranking on bolts that weren't pulling it together? I would have to think that would take some pretty serious "hammering" to screw that up.
I have ALWAYS left the torque converter on the transmission on every engine I have ever pulled or swapped, then bolted it to the flex plate after it was in. Why would you leave it on the flex plate for pulling/installing? It would make it MUCH harder to align than to drop it in front with a 1" insertion instead of 4" insertion.
What on the converter would be damage? I never started the vehicle so I am hoping I had it seated far enough in that it didn't damage anything. I guess I will find out tonight. Forgive my ignorance on all this. This is literally the 1st time I have messed with an automatic trans vehicle. I have done a ton of manual transmission vehicle swaps, installs, etc.
What on the converter would be damage? I never started the vehicle so I am hoping I had it seated far enough in that it didn't damage anything. I guess I will find out tonight. Forgive my ignorance on all this. This is literally the 1st time I have messed with an automatic trans vehicle. I have done a tone of manual transmission vehicle swaps, installs, etc.
No problem. My biggest concern having done this would be jacking up the input shaft seal, not the pump. Pull the engine back up, replace the seal with the trans still in the truck, slide in the TC (lube the shaft first....ALWAYS lube your shaft before sliding it in!), then drop the engine back in and bolt up.
inspect the input side of the TC to make sure you didn't scar up the shaft on the TC.
Pulled the transmission and torque converter this today and found some interesting stuff. It is hard to see but in the first picture you can sort of make out that the metal ring behind the seal is cracked/missing a piece. I also noticed there is this hole (second picture) that was behind the pump. Do you think I can get away with just a new pump, or is a transmission replacement in order?
How hard is it to pull the transfercase off of the transmission and swap it over to another transmission? I have someone local that has a good working pump/transmission for sale. I read some information about it being a pretty difficult job on the FJ62.
