Help identifying this part!
Texas
What is the pouch-like part in these images? Its located behind the driver side rear wheel. Mine seems to have a small cut in it and is leaking fluid, seems to be a part of the brake lines. A part number for it would be great also
LSPV (Load Sensing Proportioning Valve).
You need a new one.
Valve, 47910-60090
Bush and boot kit, 04477-60010
That is the portioning valve for the rear brakes.
It allows the rear brakes to adjust how.much pressure to apply as the weight transfers during braking
When the front end dives under braking, it gives more pressure to rear brakes to try and level out the truck.
Hope that helps
Hope that helps
Actually it lowers the pressure when the distance between the rear axle and frame increases. Increases the pressure when the distance decreases. Doesn't effect the front brake pressure at all.
You need a new one.
Valve, 47910-60090
Much thanks, I'll look into getting replacements. Is replacing the parts straight forward? Anything that I should know before-hand?
