Help identifying master cylinder
MI
I picked up a LX470 a few months ago that came with an ABS delete. The master brake cylinder in it seems to have failed earlier this week. I am trying to identify what brake cylinder is in the truck but when I google the letters/number stamped on it, they don't seem to be a part number. It also looks like there is a brake booster from another vehicle as well. Any help identifying the brake cylinder or tips for how to better fix the brakes now that the installed system is broken are appreciated. Cheers!
Looking around on rockauto, seems like maybe it's the same one used on Tacomas? Can anyone confirm?
put you VIN in on Partsouq and you'll have no problem finding it.
I was just looking these parts up the other day since I want to convert mine into a vacuum assist set-up.
This is what I got but was for a Mid-east spec but should be equivalent....47201-60720
I didn't think these trucks came stock with master cylinders like that? Since they had the whole ABS pump thing from the factory.
Deleting the abs unit as well, like a lot of theGulf Corporation Council units. They were not equipped with abs, I don't believe yours is either.
My LX has had a failed abs module for a while now and it's not something I worry about having. My last daily was a BMW 540 with a failed module for 3 years. In fact, most of the vehicles I've owned over the last 30 years, street and track, were not equipped with abs or deleted.
my truck has had a failed abs module for a while now and it's not something I worry about having. My last daily was a BMW 540 with a failed module for 3 years. In fact, most of the vehicles I've owned over the last 30 years, street and track, were not equipped with abs.
cool, so are you just replacing with 105 series booster and master cylinder? When I google that part number it looks like that's what it comes back as.
Yep, basically the plan. The 100 and 105 probably used the same units. Go to partsouq and put your vin in to see if what you get matches what you have found elsewhere.
Yeah I tried. Unless I'm doing something wrong it's not coming up with anything unfortunately.
You can DM me the VIN and I'll tell you what it came with. PR vehicles were different than mainland US. Probably no NAV and no rear heat too?
No nav but does have a rear heater. I'll DM you. Thanks!
Here is a photo of the front part of it that goes into the brake booster. I cannot find another master cylinder with a front like that except for some 80 series ones but those have 4 bolt patterns instead of 2 and the electronics are in a different location.
