If you are looking for the laminate, it’s discontinued from Toyota.
Well crap. Can I just remove it? What's underneath?
You can remove it, plastic is underneath it. It is a sticker essentially.
I would suggest you use a hair dryer on a warm day to remove it. It can be gently persuaded off the dash, but use plastic spudgers and not metal scrapers because you'll end up scratching the plastic underneath.
Once you get it all off, don't go wild on chemicals to get the adhesives off. If you go too aggressive you'll haze all the plastic. Use some mild adhesive remover.
Awesome, thanks guys. I saw the screws and just always assumed it was screwed in. Didn't realize it was all just adhesive. Is it that way on all the wood trim? Even on door handles?
I'd be fine without it, I just don't want there to be a bare spot with empty holes from the screws. Feel like that would look even worse.There is a vendor I have seen somewhere here that sells an aftermarket version of the wood grain. Not my cup of meat, but if you LIKE it, there is a replacement option.
I closed up my truck on a hot summer day, waited until late afternoon, then went out and pulled all of them off, around the radio, clock, window switches, dash dimmer switch, gear shift console. Personally, I think it looks WAY better WITHOUT it.
