I have a 89 HJ61 RHD 12ht and I have went through the whole cooling system from a new rad(re-cored) to fan cluch, thermostat(I tried 2 new ones 195 and 180, flushed system , timing checked, cooling system checked for exahust gases, valves adj. injectors checked, cooling system vac'd of all air, no coolant in the oil, no oil in the coolant ,cleaned the A.C condenser, all is perfect!! I still have a problem with heating, I am in Saskatchewan Canada it does get hot here in the summer but the temp of the engine will run at 210-220 deg f pulling itself down the highway on a 30 deg c day, I could make it over heat at will!! Exhuast temp is between 600-800 deg f at cruising and if I push it i will see 1200 deg F . , pulling a 2500lb boat is out of the question!! (It is sad my dodge mini van can tow more than my cruiser!!!!)The truck is an auto also, which I have added a tranny cooler to the sytem to help keep that safer.
CAN ANYONE TELL ME IF THE COOLING SYSTEM IS JUST ADAQUATE AND THAT IS THE PROBLEM OR IF ANYONE ELSE HAS HAD THIS KIND OF PROBLEM AND FIGURED IT OUT BECAUSE I CAN'T!!! THANKS
How is the viscus clutch on the fan?
