Here's one for all you EFI V8 experts out there.
I have a Holden 5litre EFI V8 (Holden is a branch of australian GM). Its basically and SBC block with their own heads and is 304ci. It uses a GM 1227808 ECU.
The engine developed a stumble once up to temp (running for 10 or so minutes). this quickly turns into a misfire and backfire through the intake and then dies or barely has enough to keep turning over.
If the engine is turned off and restarted it usaully goes away and is good for a few more minutes.
I have changed the coil with no success, The ECU isn't storing any codes.
I am at a loss, Could it be a faulty EFi module or ECU?
any idea would be fantastic.
Cheers
Tony
Cheers
Tony
