Help! Getting Code 31 with bad idle
So I bought my LC back in march, and just recently started to look under the hood and clean up a little bit. I replaced the air filter and cleaned out the air filter catch canister. I then decided to take a look at the throttle body. I was extremely gunky on the outside and inside. So I went out and bought some throttle body cleaner. After thoroughly reading the instruction, I cleaned it up and got it pretty clean. I also made sure to hook everything back up properly.
The car now has a rough misfiring idle and some smoke coming out the exhaust (which I expected from the cleaner). I expect it to go away. But it also threw a code 31 which is the Air Flow Meter signal (Vacuum Sensor signal). I reset the the ECU and removed and reinstalled the EFI fuse. Code is still there. I drove the car about 20 miles after all of this.
Does anyone know what could have caused this?
Also, previously when idling the cat has been shaking and getting very hot, and it seems like it might have gotten worse after cleaning the throttle body. Could it be the cat backing up the airflow causing the sensor to whig out?
While doing all of this, I also noticed that the “P” on the EGR vacuum modulator is hooked up to the vacuum inlet on top of the throttle body closest to the front of the car and has been since ownership of the vehicle… just curious what that does to the egr system and/or why it is like that.
Any help is very much appreciated! and I’m pretty nervous about the code and I hope and pray I don’t need a new AFM.:crybaby:
After doing even more research, I think I might have messed up the wiring of the AFM when taking out the plug...
But I'm still confused why the modulator is hooked up to the throttle body? Is it just someone not knowing what they are doing?
