hey guys, i noticed yesterday after having driven with the hubs locked and in 4X4 some of the time that there is gear oil all over the starter, brake & clutch lines, lower bell housing, and all over the third member. i took out the diff breather and cleaned it really good and took it out of 4X4 and unlocked the hubs and found that it's still leaking. not as much but it's still leaking. i'm wondering if it's some seal or something in the bell housing or something that is leaking. also the gear oil is really thin for some reason. i'm pretty sure it's gear oil because it smells a lot like gear oil but it's so thin and discolored from the dirt and grime it's run through that i can't really tell. not sure what to think but any help or suggestions would be much appreciated. by the way it's an 84 pickup G52 Tranny with about 192,300 miles and 22R. Thanks
Couldn't believe it.
