help fj-40 tech
im in the market to buy a fj-40 what years do i want and don't want what drive train do i want and dont want i have been a jeep guy and don't know a thing about fj-40 please help thanks
sorry about clearification
i want to know the diff in opptions and drive train thru out the years in the fj-40 good years bad years and some years i dont want to compare the cj to the fj thanks
http://www.off-road.com/tlc/faq/
IMO, best year to buy one and plan to wheel "normally", 1978
best year if you plan to granny gear and do axle upgrades, 72-73
best years to keep stock and daily drive, 1980-82
IMO, avoid 1968-older unless you are a resto king or only need a tub and frame
73-older = 3-speed tranny and 10-spline input t-case
1974+ = 4-speed
1976+ = disc front brakes
1978+ = fine spline pinions
1968/9+ = fine spline side gears
thank you
thanks for the helpany tech forums engine hp t-case axle width ext. thanks
I agree with Woody's description above. TLCA.ORG website "history of the cruiser" page has a good description of changes throughout the years. If you are a tall dude, 79 and up tub has longer legroom and is much more comfy. I've driven both. There is a kit for legroom in earlier bucket seat cruisers (Classic Cruisers in Salida, Colo.) but it does not give you the leg room of a later tub. The later "Split" T cases (80 and up?) has a lower low, which combined with the (79 and up) 3.73 rear, just about puts you in the same crawl ratio as the non split case with 4.11s. And the split case is supposed to be stronger. Plus 3.73 is waay better and faster/smoother on the road. I think if you can find a clean 81 or 82 it would be great. Not as easy to find a lift for, though; the springs are wider and fewer companies make them due to narrow year range. But I think Cool Cruisers now has a lift for them. Minuses: more smog stuff and later tubs tend to be rustier I've heard. Doc B's advice: learn, find one built like you want (V8 done right if you want one, lockers, lift, clean tub, the right tire size) and buy it. Would cost less in the end than building it yourself. Be patient.
unless your gonna beat it up, the one with the least rust and the least PO mods is prolly the best one.
8/80+ is a fj60 drivetain with a fj40 body.......
thanks for all the help
im trying to trade my 99 ford ranger4x4 77,000 miles clear title and my 85 cj/7 4" lift chevy 350 turbo 350 trans w/hard top full hard doors and some other little things done to it for strait decent fj-40 does anyone know of any other sites to try thanks for the help
