Help find coolant leak
Stc, Illinois
A couple of weeks ago I found a puddle under the tranny on the driver side, so reading the forum decided that it was most likely rear heater. So I did the rear heater bypass, moving forward 2 weeks later i still find the puddle on the same spot, engine looks dry, nothing wet by the pesky heater hose, starter area all dry. Could it be coolant still on the rear heater lines? I figured by now it would be all drain. I took a couple of pics so you can see. Is right on the corner of the tranny on the front.
Truck is a 93 w 169k miles.
Thanks for any input.
There is two bypass lines under throttle body, bypass one goes from next to the phh up to backside throttle body, then hard line thru throttle to bypass number 2 which the runs out towards radiator, then you'll see bypass hose number 3. I'd replace all three fromtoyota around 30 bucks with clamps.
Your block drain is also on the same side maybe its loose? It is brass drain plug
mine, i bypass the rear heater and I'm assuming it was still leaking whatever was on the rear heater lines and heater itself, hasn't done it in a while now. i just kept an eye on my coolant levels just to be safe.
