Help engine won't start!
Asheville, NC
After 306,931 miles my 93 FZJ80 spun a couple rod bearings. It sat for a year and I just now replaced the engine with a 97 model. I used the 93 harness and vacuum valves under the intake manifold. The replacement engine will not start. It will run on starter fluid. The injectors don't seem to be firing. They are quite - no clicking noise. I can hear the fuel pump running and the EFI relay checks out ok. Any ideas on where to start looking. All connections and grounds seem OK. I've spent hours looking. Any help would be appreciated. Thanks
If you used the 93 harness, that means you used the 93 ECU, and the 93 exhaust which has different emissions, etc, right? You're in a pretty small % that have done this, so you might provide some insight into what differences you found to help us troubleshoot from afar.
For instance, what did you do with the PAIR valves from the 93 - install it on the 97 block, or discard? Did you have a couple more emissions and block sensors on the 97 block for which the 93 harness had no connectors? Install the original tranny, or did you put in an engine and tranny from a 97? Did you just swap the blocks?? Did you open the 97 engine and put a head gasket in it? Stuff like that helps us grasp potential conflicts.
DougM
The 93 PAIR setup was not reused. Vacuum feed for its control pluged. 97 engine was complete, sensors which were different were exchanged. 97 crank position sensor not used. Transmission was replaced with a low mileage, same model transmission. The fuseable links at the battery are connected and all good. I have not checked fuel pressure, however fuel is returning to the tank via the return line. Fuel filter is new. Injectors are silent (not clicking - I listened with scope) There are no diagnostic codes recorded. Timing is close, engine runs briefly with a shot of starter fluid.
Thanks for your ideas, all are appreciated.
