Hi,
After IDave's issues with his cooling system crud I decided to check mine. Turns out I have the same crud. I've spend the past 4 days trying to get this stuff out. I'm scraping it out with a screw driver. I'm into the block about 4 inches and seem to be hitting metal when ever I go any direction now. I've tried attaching a garden hose to the drain plug in hopes the pressure whould blow the rest out. I hooked a peice of stiff wire to the drill and tried to "drill" it out. I've applied muratic acid to the plug side and let it sit all day. My question is this. If I hook an air line to the plug how much air pressure can I apply before I run the risk of cracking the block. Can I put 100% acid in the rest of the cooling system, or will it chew through the radiator? I'm up for any other suggestions too.
Thanks
Dave
Thanks
Dave
