Help!! Driver side headlight & parking light out
Opelika, AL
Driver's side parking light and low-beam lights won't work. I must have a short or damaged wire. After I got off work last night I noticed the light wouldn't come on. The driver's side High beam works fine. On the way home the interior lights and the red lit symbol located on the dash that tells you that a door is still open would flash on every once in a while. Anybody have anything like this happen to them? What can I do?
Have you tried the simple things first like changing the bulbs? It could be a simple coincidence. The flickering interior lights have been discussed numerous times here. Loose door stops or some such nonsense (non-electrical issue). A search will turn up the solution.
Ok, I did a search for flickering interior lights but no luck. It came up with a few hits but no one was talking about the same problem I'm having.
All these things mentioned before (p light, lowbeam, and flashing interior lights) all happened at the same time. I will swap the headlight bulbs to see if this is the problem but I have my doubts.
Did you check the fuses by the battery.... IIRC there is one for the L & one for the R headlight.
Actually I checked all the fuses and in the process somehow managed to cause my truck to run too low of RPMs. Almost to the point it wants to cut off. I went ahead and drove it to work and back. I thought by driving it the computer would reset itself. Is that wrong? Do I need to disconnect the battery cable?
Alright got everything squared away. Turns out jonheld was right as long as door stops are the U-shaped pieces that the door grips to stay closed. One was loose and on the same door the switch that is supposed to depress and cut the lights off works 99% of the time. It only acts up when it's cold though. I just can't believe that both the headlight, parking light, and interior lights all acted up the same night and none of it was a wiring problem.:mad:
It's a good thing though but ticks me off that stuff like this happens which makes me believe I have some kinda big problem and try to overthink.:bang:
