Help driver side headlight dim stuck at work.
Just like the title says my driver side headlights have suddenly gone dim both high and low beams. I tried new bulbs and same results. I have 11 volts accross the plug (no load) with engine off which points to a short somewhere, however it climbs to 14 volts when I start er up so it's a little short? I guess. Any suggestions are greatly appreciated!
Well the plot thickens, now the driver side is completely dead on low beam and both passenger side lights come on, but one of the bulbs is very dim. On high the passenger side appears to work correctly but the driver side is very dim. I'm thinking maybe the hi-lo relay if there is such a thing...
Not sure how this was the culprit, but the LH fuse was blown, swapped in a new one and she lives. Now the only question is how did it blow and why would it being blown cause these bizarre symptoms?
I'd look for broken or poor/corroded ground connections. I had a similar issue in one of my 80's BMW's and it was a broken ground. I was only getting about 7 volts to my lights.
