help diagnosing elocker not working
Western New York State
Hi. Trying to diagnose here in 15 degree temps. When I turn the switch to activate the elockers the lights blink front and back. We checked the plugs to the accuators and they're OK. But power to accuators is intermittent - blinks when light blinks. Between the switch on the dash and the accuators is a modulator box in the passenger side kick panel. Do u think this is my problem and that I should just replace this? Thanks. Brrrr
Are you in low range?
You need to shift to low range first (to activate the center diff-lock) before the axles will lock.
Do you get the CDL indicator light when in low range?
Sounds like you have a non-functional CDL system.
It may just be a switch. @george_tlc has a good write-up.
I put the truck into low while in neutral and then shifted into drive and drove a half block but didn't see a cdl light. I'm not sure how to search for the writeup you referred to.
I couldn't find the writeup either, that's why I tagged George.
First, give us some background on your rig.
What year?
How long have you owned it?
Any mods?
Should've done it earlier but just updated my profile page so that all my info is available. I have a 94 LC and live in Western New York State just off of Lake Erie. I've had my Land Cruiser since 2012. Haven't gone off road in it yet, but it sure feels that way sometimes here in WNY where we've gotten some big snowstorms. The truck is largely unmodified mechanically, but I've got some updated electronics to make my drive more enjoyable. I'm trying to find a thread or informational article on the lockers so that I can trace this problem. I take it from what's been written that I need to be in neutral before switching to low gear; need to be in low gear in order to activate the lockers; engaging low gear also engages the center differential lock; and if the center differential lock isn't engaging, then this may be a reason why the locker lights blink when I attempt to lock the differentials. (Power to the actuators also blinks.) Trying to trace the problem and order whatever parts are needed to allow me to lock the differentials when needed. I traced the wiring from the dash switch to the actuators and see that it goes under the hood and then to a modulator box located in the passenger side kickpanel. Wasn't sure if I should be replacing this... Any help or pointing me to the right reading material would be greatly appreciated. Thanks. Jason
...engaging low gear also engages the center differential lock; and if the center differential lock isn't engaging, then this may be a reason why the locker lights blink when I attempt to lock the differentials.
^This is your concern. The CDL can be locking OK, but not indicating it.
Can you tell if the center is actually locked or not? You would feel a binding when turning or hear a tire skipping.
Loaned my gf the truck due to the bad conditions here in western NY. Gotta wait till she gets home tonight to test it.. But just so I'm clear, even without the front or rear differentials being locked, I should feel skipping on turns with the center differential locked? Makes sense but I just want to be certain. I will test later tonight for sure.
Yup, you should notice it with just 1/2 turn of the steering wheel.
In the mean time here's some info for you to ponder.
This is a simplified drawing I made to show how it all works.
You'll see on the left, shifting to low range closes the L4 position sw. and sends +12V to pin #7 of the CDL control relay. The relay then activates the actuator motor for the CDL. Once locked, the CDL indicator sw. closes and sends a ground signal to the Diff Lock ECU (as well as the CDL lamp and ABS ECU).
So the problem may be either one of those switches (or both). You'll know which direction to trouble-shoot if you can determine if the CDL is actually locking or not.
Very confusing.... After playing around with the high/low
gear and the locker switch - engaging, driving, disengaging, over and over again- everything suddenly worked... but then later when I tried to show my gf, if didn't work. And then afterwards when I was alone it worked again. Seems like every other time I shifted into low the abs and cdl lights came on, and in those instances the differential switch worked as I read its suppose to and I truly felt the differentials locked.. so Im totally psyched for sure but at the same time I'm not sure what to do next so that I can rely on the locker system confident that it'll work when I need it. Any suggestions?
Also , is it correct that I can't use this system at speed, say 50 mph+ since it only works while in low gear? Here in western NY we have long stretches of roads where people drive at highway speed even though the road hasn't been plowed. I'd like the confidence of locking the axles when road conditions dictate but I'm assuming I can't drive too fast while in low. With my jeep i could lock the axles on the fly without being in low. What do others do in this situation? Thanks.
Like a lot of us here, they get the manual CDL switch like this one:
http://sleeoffroad.com/products/products_switches.htm
This is also a usefull tool to help determine if that L4 position switch is the root of your problem. The good news is you don't have to buy this switch for you to do the testing, you can temporarily use your hazard switch. Following the link above, click on the "installation instructions" for the CDL switch shown. It will show a harness connector behind the dash. Just unplug your hazard switch and plug it into the CDL switch connector.
Now go for a drive and see if the hazard button operates the CDL reliably.
Warning: your blinkers will not be functional.
Ha ha locked on the freeway at 50 plus hope its straight. I didn't read the slee mod but im assuming your doing the 7 pin mod . You should on and off your lockers to loosen them up, plus you have to turn abit so one wheel turns faster than the other at slow speed to lock it right. The rear has to lock first before your front will lock too. Unless you do another butcher mod. The rear plug behind the back wheel where it goes through your body is ussually the culprit if its not at the locker unit.
