Hey everyone,
I've been under the truck quite a bit while the engine is out, and this is one more mustery I'd like to solve before it goes back together.
This truck came to me from the PO with a half-installed auxiliary tank bolted to the rear bed. It looks like it had been almost completely plumbed but never finished. I pulled the auxiliary tank years ago as its a pretty poor design, but the rest of the fuel system is still under the truck. I'd like to clean it up.
Toward the back of the truck, behind the stock fuel tank, are two "things" that seem to have controlled the transfer of gas from one tank to the other at one point.
In the foreground I believe is a pump - it mentions "8psi max" on the label, and the red wire heads to a switch on the dash labeled "AUX."
I'm not sure what the other junction that hangs lower is.
I think I can just remove this whole setup, correct?
Up front, all the original lines and the charcoal canister appear to be there. It appears all the return lines had been cut and plugged, the canister is there for show, as far as I can tell. The line with an open "T" fitting is still connected to the fuel separator in the cab.
This truck will run a 350 with a quadrajet. It doesn't have emissions controls to speak of. What does a proper fuel system for this setup look like? Would a return line from the carb connect at that T fitting above?
I assume the fuel line connection on the bottom of the gas tank runs to the carb (so the fuel flows through it via gravity). I assume I would route this line to the hard line on the frame rail, to the fuel pump, then a filter, and into the carb.
My next question is - is there supposed to be a return line? Vent lines? Etc. on a quadrajet? I don't think I was running one previously...If so, how does that get routed back from the quadrajet to the tank?
Is there any reason to try and reconnect the charcoal filter or the fuel separator in the cab? They're all still there just in various states of disconnected.
