Help converting front locking diff
TN
I recently swapped the locking diffs from my wrecked 96 80 to my pristine (for now) 97 80. Everything went great, although we did have to swap the wiring harness, until it went to the alignment shop where we discovered the front housing/tube is bent.
I have seen a number of threads on converting a non locking rear to locking, but none covering a front conversion.
Has anyone done this or know if it is practical? If no, does anyone know a good source for a front locking diff housing?
Or any other ideas?
The swap is fairly easy, you have to install 2 studs and cut the hole a bit bigger where the actuator motor is. Use the new gasket as a template for cutting the hole, and then the only tricky part is getting the stud holes perfectly square to the surface. Some people add some metal with a welder to the outside edge where you have to cut, to give the gasket more area to seal against. I did not do that and mine doesn't leak 2 years later.
-Spike
The front is more challenging to notch and getting the studs perpendicular to the surface is a pain. I prefer to swap the housing. I have done one and I am about to do my wife's this weekend.
It's not that simple. The "notch" is quite large and not all the studs line up.
Notching the rear is much easier.
Edit:
Sc0 deleted his post so this answer is odd.....:lol:
I think so.
Depending upon your level of equipment and skill modifying the housing is a simple and easy sub 1 hour job with the housing out of the vehicle. I can do a empty housing in 35-40 minutes start to finish and you already have a non e-locker housing so I would not be looking for a new housing if you are sure that it is not "tweaked".
Yes.
:grinpimp:
