Help: can't get one trunnion cap back into knuckle
Is there any special sequence or method to get the trunnion caps seated into the knuckles? Got the DS on without much trouble but the PS doesn't want to go in so easy. Do the bottom nuts holding the steering arm to the knuckle need to torqued down before the trunnion cap will drop in all the way? I've got the arm seated and tightened up most of the way and have used a 3lb hammer to strike the arm to get it seated. You can see the smear of red grease squeezed out between the knuckle and steering arm mating surfaces I put there before assembly.
Got the new races pounded all the way in? Using OEM bearing/races? Was there a shim? Also, I assume you are not just cranking that cap on with a single bolt - should be both on the cap and alternating on each as it needs to go in square or can bind. Try tapping on the cap?
DougM
Doug: I did have both bolts in just before I took the photo, took one out so that I could beat on it some more, but have not been cranking down the bolts to try to close the gap, wanted to get the cap all the way down first. All new OEM races fully/properly seated seated, with OEM bearings and new shim same size as original. I also tried spinning the trunnion cap around to different positions and beating on it with a dead blow hammer to see if that would help. It all looks good, just can't get it the last 1/8th inch.
Edit: rereading the FSM, it states to install the trunnion cap first, but also says to use the SST (09606-60020) with a collar?, then install the steering arm to the knuckle, also with the SST. The FSM states that the SST's job is to support the bearing inner race. Maybe that is so that you have something other than the outer race for the bearing to be supported by when you beat the trunnion cap or steering arm cap in? Without the SST the bearings and (partially inserted) trunnion cap post seem like they would just sorta bounce around against the outer race when you bang on the cap; does that sound about right?? So I might need the SST or something like it to take it's place; found a source for the SST but it doesn't mention the collar. Either way, it would be another week to get it. Four hours wasted trying to get one knuckle back on. :bang:
Edit II: now that I recall this same trunnion cap was very difficult to pull out of the knuckle on this side (PS) when I tore everything apart. Just spent 30 more minutes working on it, torqued the bottom nuts to 71ftlbs, then tried again to get the trunnion cap in, pounding, banging, prying, twisting, turning, even tried to pull it apart to start over, no go. More I think about it that SST seems like a critical tool to have when the cap post won't go into the bearing pack easily. I'm fawked.
Kernal,
On the theory that the 4 bolts on the bottom would be better to tighten last as you're distributing the load on 4 fasteners, why don't you reverse the assembly. ie tighten the cap on while the bottom arm with 4 nuts is loose. THEN tighten the bottom ones on being careful about keeping them uniform. I recall a bit of the same issue and don't recall what the FSM says about their being a "top first" sequence or not.
DougM
I had a similar problem on mine, i just moved the entire knuckle up using both hands and hit the cap with a hammer and it closed the top gap. Then i finished off the bottom.
IdahoDoug; The FSM discusses doing the top trunnion first, but using the SST. The ElMariachi DVD shows them getting the steering arm seated first, then the trunnion cap on, but in the DVD it goes in very easy, as did the trunnion cap on my DS, just a few light taps with a 2lb dead blow hammer.
hntashdjian: Yeah, that is how I got the DS in, and the PS 90% in, but it won't budge for the last 1/8 inch.
Edit: IdahoDoug: As you suggested I took the bottom bolts and cone washers out, lifted the knuckle and the top cap went right down with a light tap; I wasted a few hours between reading the FSM, on-line, and banging on that darn top trunnion cap. Geez. Hope I didn't damage my new trunnion bearings. Thanks a bunch.
After all this self induced frustration I think the SST may be a good tool to have around if you don't want to risk beating the sheet out of the new bearings and possibly scoring the new races you just dropped in. Maybe it could be listed as an option for the recommended tools for this job, or, just get the top trunnion cap in first like the FSM says to do. :o
