Help!! Brake question
Portland, OR
CRAP!!!! I was feeling so good about myself today after I changed my break pads all the way around with brand new toyota shims etc. that I posted a question about my leaky oil pan.
Not feeling so good about myself now after I just had to listen to my brand new pads rub on my rotors for the 35 mile ride home.
WTF did I do wrong? What would be causing this?
Come through for me in the clutch Mudders I need some help before it gets dark here in Oregon!
Wow, happy to help but need much more info. What do you mean you heard the pads rubbing the rotors? Do you mean that they squeal a little or is it a really awful sound? Did you put everything in exactly the way it was before? :cheers:
brakes
I'm 99% sure everything is put in exactly how I took it out. It's not a squeal it just sounds like my pads are in contact with my rotors at all times. It doesn't really seem like I'm driving with my foot on the brake pedal but it sure sounds like it.
I used 2 shims per pad on the front. I put the sloted one on first directly on the pad then the steel one on top of that. It was a little bit of a struggle pushing the pistons in with a BIG screw driver but evetually I pushed them in enough to get the pad and both shims into place. I put the brand new gold T clip back on and put those long screw back in and the piece of wire that holds those pins in place back on as well.
Can't figure out what went wrong. Here is a question,?, after the piston depresses the pad against the rotor what pushes the pads away from the rotor so that constant contact isn't being made between the two?
Thanks for helping a rookie!!!
Nothing does really; the pads will "retract" only in the sense that they tend to float over the rotors but not put pressure on them. You may have already answered your question in the sense that your piston/s might be binding up and not really "retracting" at all. That could cause some of what you're hearing here. Not that it is right or wrong as such but I have never used my shim plates or squeal plates. If things are so super tight that you had to really work to get those in you might want to remove them for experimental purposes and see if that helps. You might also want to have someone softly push the pedal to see if the pads are clamping in crooked over the rotor, or if one of the pistons is clearly caught up. Lastly you definitely want to make sure that the everything (calipers, rotors, wheels, etc) is properly torqued and positioned. HTH. :cheers:
