help: antenna issues after install
Santa Monica, CA
So, I just installed a new antenna mast in my 1997 LC. Pulled the motor out of the fender, split the case, removed the old nylon runner from the spool, cleaned and relubed with lithium grease - all according to the many threads outlining the process. Installed the new mast and it stops about a half inch short of fully retracting. Won't go any further, even if I push. Isn't the nub supposed to stop flush with the retaining screw atop the fender? Also, when I turn on the radio, it's 50/50 whether the antenna goes all the way up. Regardless of the mast highly adjustment switch, it seems to randomly open only as much as it wants. After cycling the radio on and off a few times, it eventually sorts itself out. Been reading all the threads, but can't find anything addressing this issue. Any suggestions?
The 97 mast should remember what height it's set to. The buttons allow that adjustment. So set the mast to a height you like with the truck running. Either switch to a different source on the head unit or turn the truck off. Now start the truck or return to the Radio as the source. The antenna should return to the height it set at.
Maybe you haven't run it all the way down yet with the buttons?
I've run the antenna all the way up and down via the height adjustment switch. Also powered the head unit on and off. The antenna doesn't return to any preset position. It just randomly decides where it wants to start - and often the heigh adjustment switch will only move the antenna a few inches in either direction. If I cycle the radio on and off a few times, it eventually goes fully erect and I can the. adjust through the full range. It's just schizoid.
Makes me wonder if the antenna extend signal wire (of whatever it's called) from the HU was properly hooked up previously and working with the old mast before it broke?
Or possibly you compromised the wire that sense antenna position in the mast assembly when dragging it out of the fender? Been a long time since I did mine, but maybe you recall something that's worth checking on?
