Hi guys,
Its been a while since I've posted in here but things have got serious and I need some expert advice... I have done a bit of digging around for any potential failures of 3b turbos but didnt turn up anything relevant to my issues..
Firstly a bit of history.
About 2000kms ago I slapped a brand new GT2052s on my 3B that had about 320,00kms on it. I set the boost to 11psi max and had a pyro installed post-turbo maxing via throttle out at 550deg celcius. Oil feed was sourced from the oil pressure sender, and return line fed to the sump.
There was no oil restrictor added tot he oil feed (and talking to turbo manufacturer, its not required for the bearing type in this turbo).
Most recently I was driving along some suburban streets maxing out at about 60kph when my 3b started to run on at high RPM's. I was able to pull into a side street where I turned the car off but the engine kept running. Both hoses going into each side of the throttle butterfly appeared to be intact so I attempted to starve the engine of air via the flexible hose from the snorkle but wasnt able to completely starve it due to air coming in via the water drain of the airbox.
Next I took off the intake pipe and starved the engine of air at that point to shut it down. After getting it towed home I removed the turbo and found oil on the intake.
From airbox to intake..
- turbo intake hose is kinked due to it collapsing when trying to starve of air.
silicon reducer onto the turbo intake
little bit of oil on the turbo intake..
Hope its a genuine garret
I'd already cleaned up the inside of the intake
other bits
oil supply and adapter
oil return
I checked I could run oil down the turbo return line after installing the turbo and I checked the air filter for restrictions (it didn't appear to be any).
I returned the turbo to the manufacturer to tear down and inspect who found nothing wrong with the turbo with everything within spec.
Report can be found here http://www.phat42.com/files/turbo_failure_report.pdf
Upon collection of the rebuilt turbo it was suggested that I'd lost compression on my engine causing presurisation of the sump and forcing oil back up the return line and past the seals into the intake as being the likely cause.
To rule that out I've done a cold compression test (without the throttle wide open though) with the following readings:
1: 415
2: 350
3: 380
4: 400
Doing a wet the figures are pretty similar:
1: 440
2: 350
3: 360
4: 380
Dont know if the results are lower with my battery getting tired...
Before the battery died after doing the compression tests I reconnected the edic and tried to fire it up (with glow plugs in) and it roared to life with full revs again so I quickly shut it down. I would of thought any oil in the cylinders from when the turbo fed oil into the intake would of gone down past the rings as its sat for over a month. I wonder if its drawn oil from the intake manifold into the cylinders as I turned off the engine and it continued to run.
Having a think about this tonight.. If the governer diaphram didnt get a tiny tear but a complete tear and separated, would it show similar behaviour?
Some thoughts I had are:
1) what if it was something else causing the engine to run on and by creating a vacuum via the snorkle hose and not being able to completely starve it of air, would that then force oil past the seal in the turbo into the intake?
2) are the variance in those compression figures OK? Does it matter the compression test wasnt done with wide open throttle?
3) I have a factory paper air filter, if this was a bit clogged (I had competed in dusty conditions approximately 2weeks prior to this failure) would it create enough of a vacuum to suck oil past the bearing in the turbo and then into the intake? Would a free-er flowing air filter be better eg: K&N?
4) Would the hose from the airbox to the turbo be a potential issue? Its wire ribbed and fairly stiff.. also the hose from the snorkel is fairly stiff as so I dont believe this would collapse, and it didnt appear to be that way before trying to starve the engine of air.
5) in regards to point above (#4) would a fixed welded pipe be better than the hose that's there at the moment?
6) Would I need to adjust valves to improve compression figures? Is it worth doing the valve seats too (and precups while the head is off), again to improve compression. is this completely necessary or a nice to have as I'm on a tight budget as it is.
7) I'm going to inspect the diaphragm governor to ensure that's not causing issues but has anyone had issues where its completely separated instead of a tear? I've had a tear in mine before and its idled quite high (double stock idle rpm?)
I've removed the oil feed from the oil pressure sender so I can operate and fire up the engine to ensure its idling fine and no other damage was done.
So yeh, thats where I'm at... Any help and tips are greatly appreciated.. I'm missing driving my 40 around and its looking pretty sad in the shed so any tips or comments that'll help it get out and on the road again would be great!
Thanks,
Andrew
other bits
oil return
1: 415
2: 350
3: 380
4: 400
1: 440
2: 350
3: 360
4: 380
Thanks,
Andrew
