I just got my head back from a rebuild and while torquing it back down I stripped #14 which is up against the fire wall. After reading this thread, I decided to use a time-sert. I called the manufacturer and they do not offer a M13X1.75. So I decided to up-size the bolt to a M14x1.5 and use the 28mm inserts.This bolt fits in the head without drilling it out, and is much more readily available. The problem is, even with a right angle drill, I can't get quite get square.
Anyone have any clever ideas to get this drilled and tapped short of pulling the engine?
Yeah cut the drill bit making it shorter that way the drill is closer to the block giving it more room to the firewall
