Hello & SBC Identification help
West Va.
Hello, I am a new 72 FJ40 owner that has been lurking for awhile now. I've been able to find answers to most of my questions through searching and haven't found a need to make a post. However, I'm trying to identify the Small Block that came in my FJ when I got it and haven't had any luck with the sites I've been to on the net. I figured I could introduce myself and see if anyone here has a clue. Here are a couple pics...
And Here is the pad on the passenger side. It looks to me like there is a big "3 V" and a small "22". Shoudn't there be more #'s ? Any Ideas? Thanks in advance.
The back of the block is up pretty close to the firewall. I will try and get a mirror back in there to see it, if I can. I just hadn't seen any reference to anything similar to the stuff stamped in that front passenger side pad on the two sites you guys linked. I had already searched around on those. I'll keep looking for the #'s.
Thanks!
The number behind the drivers side head is the casting number. The mortec site will cross with that.
My block says large journal 302/327/350 (depending on which crank is in it)
Your pic shows some rather creative throttle linkage. Can we get a pic of the other side :D
The Mortec site is very accurate but keep in mind chevy has almost as many "exceptions to the rule" as they have engines. Behind the driver side head, as you mentioned, is the block casting number. If you pull the rocker cover you can get the number from the heads as well.
Rice
Rice
Ha Ha! Yeah the throttle linkage is ghetto, but that's the way it came (It's on my to do list...). :D And did you notice the duct tape holding the vaccuum line on the carb? :D
I'll dig a little deeper this weekend and figure out what this puppy is..
MJM said:
What part of OHio are you in? A few of us are up north and some down south so lets see what part you are in. My guess is the Columbus area, why I do not know just a hunch.
MJM
Yup, in the Columbus suburbs. A West Virginia transplant, though. :D
Welll, found the #'s. 3970010
The websites list these for that #:
1968 327
1969-79 350
I'm guessing it is likely the 350, since the 327 was only one year, while the 350 encompasses a 10 year span.
Edit: I just noticed the pic on Rice's post above has the same #'s....
not much just that these heads where used on smallblock 350 or 400 cid but if you have that block #
3970010 then most likely a 350 . 882 heads start of the decline of performance . don't flow as well as the older heads . large chamber heads .hardened valve seats for unleaded . these heads are know as just average flow and performance . considered the best of the worst heads to have on a 350 . nothing wrong here the engine is fine, probably if it is out of a truck also has 4 bolt mains . this engine is just a every day hauler .
