Hello from Argentina!
BUILD UPDATE.
Lots of news around here.
Transfer case: The housing was covered in grease. Got it out, cleaned it up and full disassemble to check on everything. Looking great. Changed front and rear shaft bearings, and 4 seals. Apparently it was running with almost NO OIL, around 100cc. Ready to go back up again
Now ready to tackle the front axle with a full knuckle rebuild.
Also, radiator will Get a full clean, all hoses and inlets/outlets will be replaced.
Engine got a deep clean, it was full of grease and oil, it seems it was never washed, or at least over the last years nobody gave her the love she deserved.
This is the engine after it got cleaned
ISV valve needs ti be replaced, got a Chinese one, will see how it works. Couldn't find an OEM In Argentina, and I was quoted USD 1.500 for a new one in Japan.
The radiator Shroud needs to be replaced, its cracked, already got a new one.
Distributor cap, rotor, O ring and seal will be replaced. Spark Plugs will be replaced, and also the O Rings on the valve cover.
Water pump, alternator, starter, all look good.
Battery will be replaced with an OPTIMA D34.
Once the mechanical bits are taken care of, will start with the accessories:
- OME 2' Lift, with a full replacement of bushings
- ARB Winch Bar
- ARB Drawers
- Safari Snorkel
- ARB Alloy Roof rack
I will also remove the factory rack and ribs, so a little bit of bodywork will need to take place.
So far, the general condition of the truck is great. No rust at all (thanks to all the grease and oil leaks).
Will also install Escape Gear Seat Covers, and Weather tech mats.
Hope you enjoy, and any input you can give on critical issues to check, will be deeply appreciated!
Cheers
