hello everyone
From the pics the interior looked good. I imagine most of the price is sentimental value with what he spent. A 3500 paint job isn't 3500 to the buyer.
ive searched (from yuma az) all the way from sandiego to LA to vegas to tucson and everything in between. thats a long way.
So you've been from Tucson to Tucumcari, Tehachapi to Tonopah?
Driven every kind of 80 that's ever been made?
Went from Phoenix, Arizona all the way to Tacoma, Philadelphia, Atlanta, L.A?
Northern California where the girls are warm so you could be with your sweet 80, yeah?
:D
:D
He's been everywhere, yeah! He's been everywhere man.
lol, look at the jokers.
i think im going to take some of your advise and grab one without lockers. most that i can find are salvage titled or to beat up to bother...
i hope you were being facetious. should i not get it? is there something wrong with those years?
No one hunts for a 90-92, they settle for one :D
• Dog of a motor
• Semi-float rears
• Rear drum
• No OBD2 which is very handy
• Smaller brakes
• 15" 4Runner wheels
• Boring dash
• etc etc etc
Of course I'm posting this knowing full well that there will be the detractors so you can get both sides ;)
quick question. i spotted a "94" but it doesnt have the "toyota" emblem. it has the 95+ emblem on the grill. is it possible that the later years of 94 had the newer emblem? i text the guy but im still waiting on a reply. maybe it was a fat finger on typing on his part? is there any other thing to look for that will tell me its a 94 or 95 just from the pics?
For reference, my 1996 was built in 8/1995. Typically, anything from August after production month is the next year.
Possibly. My 96 has acorn style lug nuts, which typically stopped at 1995. Look a the production date. It's possible also that the person like the 95 grille better and swapped it out or it was in an accident and they installed the 95 headlights and grille. The 95 grille is enough different that the chrome strips do not line up perfectly with the headlight trim on a 94. Some of the folks will install the 94 grille in a 95 because they like it, but they usually paint all the trim black so it all matches, but the 94 grille does not have the same chrome as the 95+.
the guy just told me that the build date is in feb 94. he also said the paint on the right front is peeling. carfax says the front suspention was checked and serviced but no accident reported. now im starting to put 2 and 2 together. front end checked out + 95 grill + hood and fender paint peeling = possible fender bender. the guy seemed honorable enough over the phone and says theres no frame damage at all. he did say it starts to vibrate at idle so im thinking it may just need a tune up or could it be something else...
which part wouldnt line up? the pics i got have the stock brush guard so its covered. hes sending pics of the grill/lights and hood.
In the 3016 pic, the grille does not fit the headlight trim. Look where the grille and headlight meet. The grille is outside the headlight trim and it does not light up. Looks like it's a 94 based on build date. What's it licensed as?
The grille does not match the headlights. Don't know if the headlights or the grille are correct for the truck. Either way, it's had work done in the front. Make your decision on what it's worth to you.
Here's a pic of my 96 grille/headlight. Look at the seam where the grille trim meets the headlight trim. Yours has been tweaked.
carfax says its a 94. i see where it doesnt line up and the hood lines are off a bit. theres also a paint drip on the bottom of the pass side hood in the pic. hes asking 4k for it and it has 205k miles. i dont know... either someone talk me into it or talk me out of it. should i pass and keep looking?
If it is what you want and locked, get it. here's how to tell if it's a 94 or 95. A 94 has a AFM in the intake from the air cleaner under the hood. A 95 has a MAF in the same place and they look very different. 94 is OBD1 and 95 is OBD2. Big difference in diagnostics and ease of replacement parts.
Have him take a pic of the engine compartment and post it. If the piece with wires going to it look like the ones on the left side of this picture (On the intake tube from the air cleaner to the throttle body), it is a 95 and is OBD2. Does it have locking differentials (K294 on the VIN tag?) Since you know it has some repair / replacement, then bargain him down to 2500 to 3000. What's it worth to you? How bad do you want it? is it the color you want? Can you work on this stuff yourself? Is your money burning a hole in your pocket?
its a 94. the tag says 2/94 and its the k292 code.
im also looking at a 97 that the owner says has the diff lock switch. it has a check engine light that will turn on but gos out. says its been doing it for a couple years. ugh. that just tell me that he doesnt really care about it and doesnt maintain it. it has 190k + and carfax reports an accident but it has a clean title. someone rear ended him and said the tow bar was hit but nothing happened. just a small dent on the rear door and never got it fixed because it was too minor to bother...
he says he will go somewhere to get the codes read and let me know...
I bought mine VERY cheap, but I knew going in that I had a LOT of work to make mine dependable. Mine was my neighbor's son's first car and it took some serious abuse and they did little maintenance on it. I have since dumped about $5K into it with brakes, axle rebuild, radiator, all hoses, belts, VC gasket, dizzy oring, plugs, cap, rotor, wires, Oil pump Seal, front main seal, tires. It is VERY dependable now and is my DD. But, I have LOTS of tools and I do this for my therapy and enjoyment. I enjoy working on cars as long as it's not body work and paint.
Good luck!
Let's face it. There is no true need to own an 80. We own them because we love them, they are a big boy hobby because there are many much more economical choices for our transportation NEEDS. Being a big boys vehicle it will require a big boy check book just like it did when it was first purchased. This is the second post I read in five minutes where the OP seemed reluctant to make a move for fear of a mistake. I bought my 94 last spring. It came with some upgrades done and lots of uninstalled parts but the best feature was the fresh rebuilt engine. This is how I sold my wife on me spending 9 grand on a 20 year old truck. Guess what, my HG blue two weeks ago after only 16k miles. Pissed me off but we assume a risk when we buy a vehicle that's been in existance for 20 years. I owned one with elockers and in my opinion ARB's are superior anyway. Good luck
