Hella 550 Light Question
Los Angeles, CA
Website
www.phipsi.net
Easy. Power from battery to switch and when I say power from the battery it need not be from the battery directly it could be a switched on ignition power supply or it could be an always on power supply. I usually go from an aux. fuse box to the switch. And I almost always wire my aux fuse boxes so they are always on. Not good for those with poor memory. GPS, CB, extra lights, etc... will drain a battery really quick. The cool thing about power to Hella lights is they always include the necessary relays so there is isn't a huge amperage draw through the switch so even a light wire would do. You could probably safely piggy back it off of something else.
I knew it was something like that....will try it out tonight. Don't have a 2nd fuse box just yet, but will find some source, cig lighter maybe.
PKP80 said:
How would I wire in order to be able to use the lights with the headlights off?
I connect mine to the parking lights instead of the headlights.
