- Joined
- Jan 6, 2010
- Threads
- 78
- Messages
- 275
Hello,
I bought the Hella 500FF kit from Wally world today and it isn't bad, actually pretty nice for $68. However, the wiring diagram that came with the kit is nearly illegible and the wiring diagram on Hella's website isn't much better as it shows different parts then what I have in the 500FF kit. There doesn't seem to be much that you could do wrong except that I can't get mine to come on. I may not have the best ground for the switch, but I'm not even sure I have the rest hooked up right.
Does anyone else have this kit hooked up on your rig? If so, can you please help me understand the proper setup and where you made your grounds?
*does this kit REQUIRE that you use the green wire to splice into the high beams? I'd rather not and would prefer to use these even when not using the highs.
Thanks,
Chris
Thanks,
Chris
