Height question
kcustom73
Stretched it...
Ottawa, ON, Canada
Looking for some help on the height of a modified FJ40.
The plans for my current 75 FJ40 project is to lift 2.5" with OME kit, shackle reversal from BTB (might as well do it now while the frame is stripped) and 31" tires.
Just curious as to the total height of the cruiser with hardtop is. I just want to make sure that I can get this out of the garage once it built (7' tall door).
So if somebody out there has a rig with this kind of setup and could take a tape measure to it and let me know the total height, this would realy ease my mind.
you will be fine. I have a 2.5" lift and 1.5" shackles plus running 34" tires. My garage door is under 7' and the top of my 40 barely rubs the garage door handle. I wrapped the handle in a shammy so i am golden....
hope this helps........although, instead of measuring your door you will need to measure your hole........ok, that sounds bad, but you know what i mean.
You don't say which series of spring reversal you are going to use. Series I will raise the truck about 2" in the front only, depending on how it's mounted. They claim a series II reversal kit (with the rear shackle mount going through the frame) provides no lift.
With a series I, one only needs 2.5" rear lift springs to balance the height front to rear. I did such a reversal and installed 2.5" springs in the front & 4" SUA lift springs in the rear. With 12.50-15 BFG MTR's my truck (which measure 31.75" tall) with the hard top is 7'-1". Without the hardtop it is approx 6'-10".
What is important to consider is that in most cases a 7'-0 door does not allow a 7'-0 tall vehicle to go through because 7' is the height of the opening, not how high the door raises. I had a 7' tall door on my old house before I did my SR & lift as it would not fit after lifting. I had 8' tall doors put on my new house and solved that problem.
All that being said, if you do a series I and 2.5" rear springs only you should be fine. If you do a series II and 2.5 front/rear you should be fine. If you do a series I with 2.5" front and 4" rear it is going to be real, real close with the hardtop and should just fit without the hardtop.
Oh, and a series I with 2.5 front, 4" rear with 31's may look a little silly. Kinda like SOA with anything less than 37's. JMO, though.
Thanks for the info guys.
The actual seize of my "hole" is 6'-9" but used the 7' dimension for ease of message;)
I was looking at the series II reversal as I like the in the frame system and with 2.5" OME lift at both ends , it should give a good ride (for a land cruiser) for a daily driver.
My preference would be 33" tires over 31". The extra "rubber overdrive" would be helpful and I think they would also look better on the rig. Now I just have to find one that isn't 12.5" wide.
The series II with 2.5" lift on both ends with 31"s will be a great set up. For an overdrive, one thing you may want to consider is changing your complete third members out to one's with 3:70 ratio R&P's if you want a real inexpensive overdrive and stay in the height range to be able to park in your existing garage. They are plentiful, cheap and if out of the front of an FJ60 or later FJ40 can have very little wear. I bought two for $200 and love them. 80MPH at around 2600 RPM w/ 33's.
I was thinking about going with a 3.70 R&P setup. It seems everybody want to get rid of them for something lower. I'll keep what I've got now nicely stored away somewhere if I ever decide to turn the 40 into more of a trail rig.
With the great info you guys gave me, I think I have most of my drivetrain & suspension figure out. The only thing left to decide is if I leave the open diff, go to LSD (front & back) or add a locker (front & back). The 40 will be a year round daily driver so it will be seeing some very snowy winters sometimes and it might get out on the trails a couple of time a year. Maybe I'll just add a rear locker???
dont stress too much, just let some air out of the tyres, instant lowering......:hillbilly:
Airing down did cross my mind but when you have to do it every day during the winter months (didn't spend all that time and money building a heated garage not to park it in there) it's going to be a PITA.
