HEI Problem
tennessee
I was hoping for some help reguarding my s.b. 350 in my cruiser. It has been parked for many years as the restoration has been in progress, and today was the day to start the engine. Unfortunately I have no spark. I started by replacing the cap and rotor, no success then the coil, still dead, then the module, harness with condensor and the reluctor ring, sill nothing. Everything is new... I have all of the plugs out, and can start the engine spinning with the switch with a couple of spark plugs grounded for observation and still have nothing. I have measured the voltage at the coil from switch to drop from around 13 to 9 volts when the starter is engaged, however I can't imagine this being to little voltage. Any ideas?
Clint
I thought I would post the problem so that others may learn from it, the reluctor ring was the initial fault, which I fixed, but when I did I also put a brand new module on from advance auto which was bad... I started swapping out old parts and finally figured it out.
