HEI F engine
Carstairs AB
Hello all. I'm back on HI8 after being away for many years and I'm inseach of some much needed advise/help.
History:
Bought a 1973 FJ40 w/F engine, retard dizzy and eltronic ignition upgrade, flame thrower coil and desmoged. Note: it ran slightly rich when purchased and poor throttle response.
Upgrade and clean up:
I rewired the whole engine bay, All new vacuum lines, fuel lines, rebuilt card, valve adjustment, HEI dizzy, new plugs and 8.0mm plug wires. Pretty much a top to bottom tune up.
Issue:
Starts great. Idles great, responds great...... Once it reaches full operating temp it smokes and seems to be running rich. Turn engine off wait 5mins start back up no smoke till it starts to reaches full running temp. Also with it at full operating temp the carb is more differcult to adjust/dial in! It takes 1/2 turns on idel mixture and air mixture screws to make a noticable difference instead of 1/8 or 1/16 turns.
Things I've checked and adjusted:
Valve clearance all good, increased plug gap from 0.032 to 0.042 (plugs slightly black), timing set to 10 degrees BTDC not 7 degrees, check for vacuum leaks (all good). Seemed to run slightly better but once again it started to smoke again once it reached normal operating temp. Vacuum at 15 to 17 psi.
So what I'm leaning towards is plug gap 0.045 timing 12 degrees BTDC. But I don't have high hopes. Any other suggestions???
Also because it had a retard dizzy do I need to do any special adjustments to the timing with the new HEI advanced dizzy? More advanced or retard?
If it ain't broke don't fix it.
Does it run good?
Valve seals?
I haven't took it for a run yet because or concerns of damage. The smoke is not blue at all and smell very ritch like unburnd fuel.
I’m no carb expert and don’t know if you’re running the stock carb, but when I replaced my vacuum retard dizzy on my 74 with a vacuum advance dizzy, I had to get a “ported vacuum” port drilled and installed on my stock carb. I sent mine to Jim C (FJ40Jim). He did a rebuild and installed the port.
Stock carb but none ported. I just used exhaust manifold for a vac source to the HEI. One thing that was odd the retard dizzy was hooked up there as well. Carb plunger before rebuild was pinched between top and bottom plate it had a big rip in it. So was never right from the get go. Another thing I’m questioning is jet size. Any ideas on a stock size for stock carb Desmoged. I did a compression test last nigh and all cylinders are around 112psi. Even ran a 10gauge wire directly to dizzy to confirm that the correct voltage was reaching dizzy. No change in smoke.
