Hei Dist. conversion for TBI
Okay, I have spent most of this evening searching for information on coverting my Vacuum Advance HEI Dist.(MAF) to work with a TBI Kit I'm considering. Most likely it will be Affordable Injections Kit. Have gotten bits and pieces but not the whole story. Really need step by step instructions for this. Obviously the Vac retard needs to be dealt with and maybe? a different module..some say from a corvette? Any help would be appreciated.
look on ebay for them i got mine with hypertech coil for like $58.00 plus shipping for a TPI set up i am working on. the coil new sells for $65.00 good luck and i wish i could help you more!
you need a 7 pin module.also you need to make an arrestor plate for the vac advance mechanism. the ECM will control the retard and advance timing when you go GM TBI. I used to have some pics posted about this mod . do a search and you'll probably find more info.
You definately need the 7 pin module. You might be able to get away with not hooking up the spout connector in the EST wire to disable computer controlled EST. Then you could run vacuum and mechanical advance.
but why would you want to? The ECM monitors a whole bunch more variables than manifold vacuum and engine RPM to adjust timing. It can do a better job.
