Heating The Pitman Arm? Safe?
San Diego
Website
youtube.com
Having an unbearably hard time getting my drag link off of the pitman arm. The other 3 TRE's came off with ease, the one attached to the pitman arm appears to be VERY firmly in there. It has soaked in PB Blaster for over 24hrs and i have wailed the PEE out of it with the hand pickle fork and a 3lb hand sledge and its not budging, doesnt even feel like it wants to give.
Was thinking the next step is to heat up the pitman arm and try it again.
Is it safe to apply heat to the pitman arm? Does it weaken it?
Thanks
Use MAP gas to warm it up.Dont use a torch.It will heat up to fast.There is also a tool available that is ment for the job.Kind of like a 2 jaw bearing remover but much more stout.You can run an impact wrench to get it off.
What is MAP gas?
Yes, a friend is on his way over now with the tool :D
Mapp gas burns hotter than propane.
MAPP gas is liquefied petroleum gas mixed with methylacetylene-propadiene. MAPP is the tradename for a product of the Dow Chemical Company. In Australia it is known as RazorGas and is a trademark of ELGAS.
The gas is used for welding due to its high combustion temperature of 2927 °C (5301 °F) in oxygen. Although acetylene has a higher welding temperature (3160 °C, 5720 °F), MAPP has the advantage that it requires neither dilution nor special container fillers during transport, allowing a greater volume of welding gas to be transported at the same given weight. Also, MAPP is advantageously used in underwater welding, which requires high gas pressures (under such pressures acetylene decomposes to explosive hydrogen and carbon, making it dangerous to use.)
The gas is also used for brazing and soldering, under combustion in ambient air, where it has considerable advantage over competing liquid petroleum gas (i.e., propane-based) fuel due to its higher combustion temperature. A typical MAPP gas brazing operation would involve using it to silver braze (sometimes colloquially and inaccurately called silver solder) steel parts together.
This gas is popular among glass lampworkers, for instance among glass bead makers.
Its biggest disadvantages are cost, being between two and four times more expensive than LPG (depending on quantity, supplier, and bottle size). While 9 kg LPG cylinder are common, the largest MAPP cylinder in Australia is 3 kg.
MAPP is colorless in both liquid and gas form. The gas has a pronounced garlic odor at concentrations above 100 ppm and is toxic if inhaled at high concentrations.
We are going to try a small propane torck (all we got)
Will let ya know
Thanks
Well, the small propane torch worked like a champ!
Got the Slee tie rod and drag link on! Woo Hoo!
