Heating & bending shift canes.
Using the ring test it would appear that the main gear shift cane is forged steel, whereas the transfer shift cane appears (and sounds) to be a casting?....Has anyone heated and bent the transfer cane successfully ?
Yep, heat and bend at will.
I have also cut and welded them with no problems.
I was thru my early PTO shifters today. Those appear to be made the same way as the transfer case shifter. I only have one straight one the others I have are custom bent which the case on most of these. While not custom bent on purpose have gotten bent. Never seen one snapped off.
