Heating 3fe
Hey there guys I've been having a problem with my 92 fj80 for a couple years now and we've replaced the heater core about 3 times. We've constantly had troubles with this beast warming up properly generally taking about an hour or so. I'm just wondering if you guys have experienced this problem and also if you have any remedies for this thanks so much!
Has the thermostat been touched? One of the standard suggestions for a cold 2F, 3Fe that comes up in the 60s section is that you may be missing the o-ring that sits atop (?) the thermostat, allowing coolant to by-pass it.
Or are you talking simply about interior heat rather than engine temp?
heat
Well the car almost never heats up, its just really cold both interior and coolant gauge wise. Thanks for the quick reply but yes definately a bit of both
Ditto on the thermostat. Mine hadn't been heating up more then lukewarm. Put in a new Thermostat/O-ring, and presto...instant heat, and it runs very well now. If you haven't put one in, I would remove your current, and check for the O-ring as others have said.
Thank you so much guys I'm going to put a wtb up so I don't continue to freeze my ass off
IIRC, the T-Stat is only around $30... Better to just go buy one from the $tealership and be done with it.
i love not havng to post a thread for the same question...i h8 mud is awesome! thanks sillst for the thread work and thanks all the rest for the post..
