Heater resistor
Boise, ID
Hi all,
The heater blower in my '71 FJ40 only has one speed. It sounds like this is a problem with the blower resistor. Anyone know where to get one of these, or a suitable replacement?
Thx.
I found one off of my Dad's Bronco project I think would work, otherwise most older vehicles use the same resistor type system, you could look for one of those.
Here is some information that I have "acquired" over time from other postings similar to yours:
AFAIK, neither the 76 nor the 77 have a switch that is only for the rear
heater, that was only on earlier model, two speed rear heaters. On the later
ones, the first position runs the front heater on low and the rear heater is
off. Pull the knob out all the way and the front comes on full blast and the
rear comes on full blast. Early models like my 71 have two switches, each
with a high and a low speed. The connector for the later one speed is a
single bullet (blue wire IIRC), earlier is a two pin bullet type. I do not
know the year of the change, but I am sure it was between 71 and 76. I have
one of each at home I can take a look at for you to verify wire color.
> While we are on the subject, this always seems to come up this time of
year when people discover that their low speed doesn't work any more.
Replacement resistor for the front is 1.2 ohm 50 watt ceramic wirewound, 1
ohm works fine. Rear is either 6 or 8 ohms, forget which, but it is 10 watt
ceramic wirewound. Having one or both of these resistors open up in a 20-30
year old cruiser is very common, fortunately these are industry standard
components available from a variety of sources such as digikey and mouser.
> Happy cruisin'!
> Jeff Zepp
Hope it helps!!!
Brian
cruiserparts.net have them.
