Heater question
Bend, OR
Been searching old threads but can’t seem to find one that addresses my exact issue. Rear heater works good, front heater blows but just cold air. Any suggestions?
good air flow but cold?
are the pipes/hoses out the side of the heater hot? if not there is a circulation issue.
the rear heater is just "T"d off the front heater
If you’ve checked the front heater core and determined it is not clogged and is, in fact, heating up properly, then check the operation of the flaps inside the heater box. If they’re stuck in the “vent” position then you’ll just blow cold air all the time.
